Donation Edition Win
dadadada
i downloaded the Donation Edition for Windows but only the portable Verison works.
The zip Folder of the "normal" Version seems damaged or empty. I cant unzip or install this version.
Version 12.1
16.03.23
Greetings
Daniel
therube
Did you try downloading it a second time?
(Rename the first attempt, first.)
On my end it worked (the ZIP itself).
Have a utility to "test" the ZIP?
You can do it with unzip.exe or 7-zip or (I suppose a GUI zip program)...?
unzip.exe -t FreeFileSync_12.1_[Donation_Edition]_Windows.zip
7-zip.exe -t FreeFileSync_12.1_[Donation_Edition]_Windows.zip
The freefilesync.org web hoster is glitching out AGAIN. Trying to get past their level 1 support is like talking to inmates of a lunatic asylum. Intelligence-crushing.
dadadada
I just downloaded it several times but it never worked. But now it worked. seems that it was indeed a temporary glitch.
