missing something, can't auto resync
I have setup a FFS batch file and using RealTimeSync is works fine, but only once.. it won't check folders again until I have closed done the log window and clicked on the RTS TSR again..
When you save the config as a ffs_batch file, check "Run minimized"
thank you that worked
