VeraCrypt Containers
fpmpaolo
Hello people, I'm running the latest FreeFileSync "donation edition".
I have 2 VeraCrypt containers, one is in my USB Stick - I will call it A.
One is in my laptop's HDD - I will call it B.
I made a "Two way" batch file, it's running in startup via RealTimeSync.
When I log into my PC, I open the A+B containers with VeraCrypt.
I need to synchronize A to B.
When I work inside A, batch doesn't automatically synchronise files in B. I have to load it manually.
Why? thanks for your help
fpmpaolo
Ok. I found what the problem is but please help me solve it.
RealTimeSync shows a pop-up windows once it opens.
After synchronization, pop-up stay on. If I minimize the pop-up, it starts synchronizing.
I need to make this pop-up minimized.
I'm running Win11 64bit and FFS donation 12.1. Thanks.
To prevent confusions:
It is not RealTimeSync (RTS) you are talking about, it is FreeFileSync (FFS).
In order to run FFS minimized, you need to save your sync configuration as a *.ffs_batch file, and follow the instructions as described here.
fpmpaolo
It is not RealTimeSync (RTS) you are talking about, it is FreeFileSync (FFS). Plerry, 21 Mar 2023, 10:42
You're right man, thanks. I was in a rush when I read the instructions, I'll try it later.
