I use FFS on Debian with gnome windowmanager. I have installed an gnome-extension to display tray icons. This all works well.
For my daily task (keep roughly 50000 files on two sides in sync) I configured RTS, which works well although. With one exception: the tray icon is not displayed. There is some space in the tray where I can click on RTS like an invisible icon.
If I reload the gnome extension, the icon appears.
I have played with the amount of files and I think there is the reason for the problem. With a few thousand files the icon is displayed. Perhaps the command to display the icon must be before scanning the directories with inotify.
With regards, Helge
RTS on linux: no tray icon watching a lot files
