will only sync 7.8G of 24g
jonpray
Have been using Freefilesync happily for a few years, updating from laptop to My Cloud Home.
It has been downloading my windows 'documents' folder.
Last week, it started not syncing all the folder. The folder is 24G but it only does 7.9G.
looking at the info, it is clear that it is missing a whole lot of folders within the folder.
I have checked the source and destination =addresses, deleted program and reinstalled, ( a few times) but no joy!
Any advice?
Please keep simple as I am not a computer wizz.
therube
So is "cloud" now your source?
And "documents" is the target?
Just what are your source & target directory locations.
Include/Exclude filter settings?
What do the logs show?
jonpray
the source is documents on c drive of my laptop, and target is on Z drive, which is my home cloud. BTW I am doing an 'update'.
jonpray
exclude:\System Volume Information\
\$Recycle.Bin\
\RECYCLE?\
*\thumbs.db
*ffs*
include just has *
jonpray
log shows completed successfully and
21:50:45 Info Comparison finished: 4,122 items found | Time elapsed: 00:00:04
Run a compare and post a screenshot of the results
jonpray
I have just, somehow, sorted out the issue. I don't know how, but for now its working.
Thank you all for your help.
