Every time I run a compare, I get the error message below. How do I get it to
stop appearing, other than Ignore, which doesn't seem to be the best solution.
I assume it is there for a valid reason.
Initial synchronization. Please verify default copy-directions!
(No database file existing yet: "C:\Documents and Settings\user\My
Documents\sync.ffs_db")
sync.ffs_db
Please don't double-post
-> [404, Invalid URL: https://sourceforge.net/tracker/?func=detail&%3Baid=2880997&%3Bgroup_id=234430&%3Batid=1093080]
[404, Invalid URL: https://sourceforge.net/tracker/?func=detail&aid=2880997&group_id=234430&atid=1093080] This is an invalid url.
What is the answer to his problem? I have it also.
You can ignore this warning safely. I've rephrased the text for the next
version to make it sound less intimidating.
The sync.ffs_db annoying me, sorry.
I don't need the file sync.ffs_db.
Version 2.1 of 2009 is working very well and makes no sync.ffs_db.
Please give me a switch for on / off to create the file sync.ffs_db, thanks.
Use a variant other than "automatic" and you're good.
