The Default Sync Method Should Be - Update
therube
Because it is "safer".
IMHO.
And aside from RTFM or anything else.
There is less likely to go wrong with Update sync vs. other methods.
A user then wants to use some other method, fine, let them.
But make them make that conscious effort to do so.
(As it is, I use Update.
I might use some other method, but I'd have to read & understand, very well, just what the implications are in using other methods [& I don't know, particularly].
The other day someone asked me... & I said - FreeFileSync.
And I threw it onto their computer.
And I said "Update - because it is safer".
And they said, well what about... & I said, "Update is safer".
And if you want to use some other method, then go about & read & learn - first.)
then by the same token, IMO, & in IMO even if that isn't the reasoning ;-), is that the default Sync method should be an Update sync, rather then Two way, simply cause, well, IMO, Update is "safer", in particular for a novice user.
viewtopic.php?t=9914#p36692
IMHO "two way" is safe enough, and also a "true synchronization", which is what one can reasonably expect from a sync tool, while "update" is not. "Two way" does not delete any files upon first sync, and even during the second sync, the recycle bin will be used.
IMHO "two way" is safe enough, and also a "true synchronization", which is what one can reasonably expect from a sync tool, while "update" is not. "Two way" does not delete any files upon first sync, and even during the second sync, the recycle bin will be used. Zenju, 27 Mar 2023, 18:10
+1 Couldn't agree more
daveman
I would like an option to set the default sync method.
Should'nt be too hard to set up?
dave
daveman
any updates?
If you are not happy with the default settings (when defining a sync configuration via "New" ), you can always define a sync configuration according to your own preference and save that as e.g. MyTemplate.ffs_gui.
Instead of creating a new sync configuration via "New", you now open your MyTemplate configuration, modify from there and ultimately save the sync configuration under its own, specific name ("Save as").
Make sure to keep a backup of your MyTemplate.ffs_gui file, for when you accidentally would use "Save" instead of "Save as" when saving your newly created sync configuration.
daveman
that is a fine suggestion, but I wonder why we can not have an option in the settings to contropl the default sync method.
Can this be added?
Can this be added? daveman, 15 Jun 2024, 12:35
Because then the number of posts, help requests, and bug reports would increase because a user has changed from the default setting and then later forgotten about it ¯\_(ツ)_/¯
markusoft
It should be an option in settings what you want, I FIND IT VERY DANGEROUS for MIRROR
daveman
Because then the number of posts, help requests, and bug reports would increase because a user has changed from the default setting and then later forgotten about it ¯\_(ツ)_/¯ xCSxXenon, 16 Jun 2024, 17:37
if you go by your comment, then there should be no default settings at all. I think the Default should be UPDATE and not Mirror. maybe the program developer could do a poll survey if they do not want to add this option?
meteorquake
I generally use mirror. I can see the merits of Two-Way or Update as the default.
Safest perhaps is a default unselected, forcing the user to choose, the synchronise popping up a request to set it until then. Either that or Custom: do-nothing which could be presented in a similar way.
therube
So I just read:
This was given to me from AI, it doesn't work and would appreciate the correct way to start syncing my...
And I'm thinking, great, AI, so no one no longer needs to actually think.
Which... made me think of this thread, cause when people stop thinking for themselves (which does seem to be the modus operandi these days), this, default Update, may just become more ... important.
Lest the brain dead come here & say, "heh, I just lost all my data".
favoredrive
This is a synchronization tool, not cp/rsync/rclone...
