Dear forum, for some reason I don't see the content of the backup folders configuration anymore. Can you pls tell what I overlooked here? Thanks.
[SOLVED] Missing backup location information
The layout of your FreeFileSync (FFS) GUI looks "messed up" (e.g. not showing your left and right base location(s) ).
You can reset the FFS GUI layout via Tools / Reset Layout.
For seeing the "content" of your sync locations, you first need to run a Compare.
After that, by default FFS will only show the proposed sync actions, if any.
If left and right are identical, your Compare result windows (your 1 and 2) will appear empty.
But by clicking the "=" icon mid below your window 1 and 2 it will also show all files that are equal.
Thanks. Appreciate your help.
Best, Jos
Best, Jos
