Is there any way to import a list of folders into FFS? I have 135 User Profile folders I need to copy from one server to another, and I have the full folder paths for each folder in a csv file. I would like to import the list of folders into FFS to run the Mirror. Is there any way to do that?
TIA!
Import list of folders
Convert the folders to relative paths and put them into the include filter. The alternative would be to edit a .ffs_gui file to add folder pairs, but loading it will create a GUI performance problem, and also be unwieldy to manage.
Basically, just sync the whole "Users" folder and use filters to include/exclude what you want
