Installing 12.2 on 64-bit debian linux?
shg_co
I'm trying to install FFS on a 64-bit Debian GNU/Linux 11 ("bullseye").
But i can only download a 32bit version of the installer. This will not run on my system.
Where can i get the 64bit version of the FFS-installer?
Thank you in advance.
therube
So you've actually tried this & it doesn't work?
The tar contains a run, that then contains both 32 & 64-bit binaries.
shg_co
When i use "file FreeFileSync_12.2-Linux.run" then it results me in 32-bit ELF format. S the executable contains only 32bit version.
