Misleading error message ENOENT: No such file or directory [lstat] - But all does exist!
FDU
I sync MS Surface Pro 6 with MyBookLiveDuo (MBL) and MBL with MacBookPro. MBL purpose serves as back up for both notebooks. FFS provides above error message although file and path exist for numerous items.
e.g. Fehler Die Dateiattribute von "/Volumes/SmartWare/_live_data_tranfer MS-MacBook/... 2205.xlsx" können nicht gelesen werden.ENOENT: No such file or directory [lstat]
It affects some links and files (not all!) although they are existing and I do not get the error message on the Windows side Surface with MBL but on the Apple side MBL to MacBook. Any explanation or work around?
Thank you.
FDU
Hi I just tested the idea to do the sync from MacBook side with MBL using the Windows environment installed thru Parallels and found out there is no such issue as described above. So the wrong error message comes from sync b/w Microsoft and Apple environment ... just in case someone is interested and likes to work on it ...
Lynxlynx
Hi. Did you manage to solve this problem? I have a similar issue with external hard drives (I used two of them) where I saved data on Windows and wanted to use them on my iMac. However, in the Mac OS system, some files are not visible, even though there's no problem on Windows.
