Cannot deactivate Write File Permissions (DACL, SACL, ...) in RealTimeSync
Despite being deactivated in FreeFileSync Options and working without any Problems there, when the batch file is used with RealTimeSync, it tries to write FilePermissions (DACL, SACL, ...) which then fails to do so and also should not do this. Can anyone help me?
You unchecked that option and re-saved your .ffs_batch configuration file?
Thanks for your reply!
Yes I did that at first but simply re-saving the batch file did not work!
Apparently I tried it again creating a totally new synchronization job and pack it into a batch file, then it worked...
Interesting! At least it's working
Indeed! Thanks!
