Failure to auto-update with donation edition
Dekker
Attempted to use auto-update, file appears to "download" with progress bar, then received this error message.
Command
""/home/xxxxx/Downloads/FreeFileSync_12.2_[Donation_Edition]_Linux_Install.run" --directory "/home/xxxxx/FreeFileSync" --autoupdate" failed.
Exit code 1: sh: 1: Syntax error: ";" unexpected
Could not find path to terminal executable.
Attempts to auto-upgrade again now skip the download, but jump straight to the error message. Of course, terminal is installed ;)
Manual update worked fine...
Any ideas?
Lubuntu 22.04.2 LTS x86_64
FFS 12.1 x86-64
