GUI Configuration Files of version 3.2
matidio
someone can show me a way how to transform my configuration files of version
3.1 to version 3.2? The problem is that all the "alternative filters" aren't
read into the new local filters by version 3.2 and therefore are lost.
Any hint other than to edit them manually?
PS: I suppose the same is valid also for batch files ...
You need to edit the *.ffs_batch/*.ffs_gui files and change the XML node key
from "AlternateFilter" to "LocalFilter", then try to load them again.
matidio
Ok, shame on me. First thing which should I have thought of ...
