PB with RealTimeSync for files .zip
vika51
Good morning
I'm having trouble syncing .zip files. RealTimeSync waits indefinitely after it starts transferring. Have you ever had this case, mine is systematic with .zip files, whatever their size?
THANKS
therube
Aside from RTS, if you attempt a similar regular sync, does that work correctly with .zip files?
AFAIK, FFS does not treat .zip files any differently from any other file.
So might something else be interfering, like your A/V is trying to scan the files?
