Installation Error code 0x80040154
hermeneut
I got this error while doing an automatic update to my donationware FreeFileSync.
It tells me to reinstall. I've done this multiple ways, e.g., simply installing a new install over the old non-working one. uninstalling and then installing. Uninstalling, re-booting, then installing. Nothing works. I keep getting the same error screen. never had a problem before. Any help appreciated.
Using Windows 11.
hermeneut
Thanks for the quick reply. It seems to be working.
