How to download Realtime
Gerald77
The majority of the time I have been using a paid FreeFileSync file; however, I am now considering trying out the Realtime sync, and noticed in all of my updates that has not come along with the extraction file which I used to have when I first started using this application.
Please where is the link to download the full application of FreeFileSync with Realtime Sync?
therube
There is no separate (download for) "RealTimeSync".
It is included in the FFS download.
It is named, "RealTimeSync.exe" (in Windows) & should be in the same directory where FreeFileSync.exe exists (with associated files in the /Bin/ subdirectory).
Do a search & see what you find.
Gerald77
Thanks for your reply; however, I am using macOS and I do not see the "RealTimeSync" included in the FFS download. It is missing.
That's not how it works
When you install FFS, it also installs RTS. There is no possible way to not install RTS
Gerald77
Hello, all and xCSxXenon30 Apr 2023, 14:23,
With all due respect, to the comments trying to help me out, I have tried several times and still only receive
FreeFileSync_12.2_macOS.zip which expands to FreeFileSync_12.2_[Donation_Edition]_macOS.key and FreeFileSync_12.2.pkg. There is NO RealTimeSync package. As you can see I have my donation edition, but lack RealTimeSync.
I am able to install FreeFileSync_12.2.pkg, no problem; however, there is not RealTimeSync.
Maybe because I made a donation the packages I get download are modified in some way. I download off the website and it still says donation version, but no RealTimeSync for me, and no way to contact the company.
Donation has nothing to do with it. Installing the "FreeFileSync" package installs RTS as well
Have you checked in your "Applications" folder in Finder?
Gerald77
How embarrassing, for me.
xCSxXenon - You were right! It is in my Applications folder. My mind would only look for FreeFile..., rather that RealTime.
My assumption was that they would appear together. I was wrong!
Thanks xCSxXenon, you helped.
therube
I cannot install it, so I can't tell you if the install works, correctly, but I can see that "realtime sync" is there.
Do a search on your end for "RealTimeSync" & "RealTimeSync_main".
Do they exist? If so, where?
C:.
├───FreeFileSync_12.2_[Donation_Edition]
│   ├───FreeFileSync.pkg
│   │   └───Payload~
│   │       └───Payload~~
│   │           └───Applications
│   │               └───FreeFileSync.app
│   │                   └───Contents
│   │                       ├───MacOS
│   │                       │   └───FreeFileSync_main~
│   │                       ├───Resources
│   │                       └───_CodeSignature
│   ├───RealTimeSync.pkg
│   │   └───Payload~
│   │       └───Payload~~
│   │               └───RealTimeSync.app
│   │                   └───Contents
│   │                       ├───MacOS
│   │                       ├───Resources
│   └───Resources
│       ├───ar.lproj
(language files removed)
│       └───zh_TW.lproj
│           ├───conclusion.rtfd
│           └───readme.rtfd
└───__MACOSX
C:.
    └───Contents
        │   Info.plist
        │   PkgInfo
        ├───MacOS
        │       RealTimeSync
        │       RealTimeSync_main
        ├───Resources
        │       Icons.zip
        │       Languages.zip
        │       RealTimeSync (boxed).icns
        │       RealTimeSync.icns
        └───_CodeSignature
                CodeResources
(And I see you've found it.)
