Local Disk>FTP
kissbzm
How to set up
Real time synchronization(RealTimeSync.exe)
Local Disk>FTP
https://freefilesync.org/manual.php?topic=realtimesync
https://youtu.be/9KXo6yOhTWo
Note that FTP does not support directory monitoring.
But, as your sync seems to be LocalDisk => FTP it would be uni-directional, with changes only originating on your LocalDisk. There is no need to monitor the FTP location for changes, as those will always result from your FFS sync. You can therefore remove the FTP location from the RTS configuration.
kissbzm
But, as your sync seems to be LocalDisk => FTP it would be uni-directional, with changes only originating on your LocalDisk. There is no need to monitor the FTP location for changes, as those will always result from your FFS sync. You can therefore remove the FTP location from the RTS configuration. Plerry, 06 May 2023, 11:26
No need to click on start
RealTimeSync_ x64.exe
Start directly after running
kissbzm
Just run the shortcut modification directly
