Donation Edition Docker
MrWuf
I recently made a donation to gain access to the Donation Edition. Does anyone have experience or a guide to installing the Donation Edition as a Docker container? I would like to install it on my Unraid server but am relatively new to Docker.
arrior
I'm in the same situation. Did you figure it out? I would love some help. Thanks!
MrWuf
Unfortunately, no.
CamaroOB
Same situation - posting to follow this thread; thanks!
You would have to create your own Docker container with your specific copy of the software. Docker isn't officially supported so you'd be responsible for any of the future updates also
ashish101
Same Situation following the thread, please can someone make this
arrior
Same Situation following the thread, please can someone make this ashish101, 10 Jul 2025, 15:32
Any chance you are on unraid? That’s how i got it to work. Im not that good with docker stand alone.
update.freak
I also want to install the donation version to docker on my NAS.
There is a docker version for the normal FreeFileSync Version: https://github.com/jlesage/docker-freefilesync
and there is also a feature request for it:
https://github.com/jlesage/docker-freefilesync/issues/17
In the ticket this is mentioned:
To my knowledge, the donation version is a different binary and it is not open-source. Probably that the license key doesn't activate new features, but just allows using the binary.
In summary, the key cannot be used with the open-source version this containers implements.
