I looked, but didn't find the solution so here I am. :)
I have a simple connection between two points. The transfer (FreeFileSync) works fine, and when completed a dialog box appears telling me the job has "Completed Successfully". This is fine, but unless I click the "close" tab in the dialog box additional files dropped into the source folder aren't transferred. However, if I click the "close" tab the additional files are transferred and the "completed successfully" issue repeats.
My question is this: How can I eliminate or cancel the "completed successfully" dialog box from appearing, or how can I prevent it from blocking additional file transfers?
I use this program between my observatory and my local server. While the observatory is active, files are being copied and occasionally there is no activity. During these times the "completed successfully" issue appears requiring me to click it before more files transfer. Some nights I have over 325 Gigs of data copied over, most of which are 225-Meg files.
Hoping for a simple solution, I do like this program so far.
Thank you,
Larry
Synching stops when complete, won't start till "completed successfully" tab is closed.
Ahhhh...
When saving as a batch configuration, make sure to check 'run-minimized' and probably 'Ignore errors'
That did it. Thank you.
Tried about everything except that, so why am I not surprised. Lol.
Thanks again,
Larry
Thanks again,
Larry
