Screen captures:
https://imgur.com/a/fvYoTuE
As you can see, yesterday I had several backups from the FFS batch file which runs from task scheduler. This happens regularly, usually a few days after my last reboot and continues until I reboot.
The screen grabs show all the log files, the task in task scheduler, and the instances running in task manager.
Help?
Windows 11. Newest FFS.
Thanks.
FFS batch file in task scheduler causes multiple backups daily instead of one
(heh. i got a message about "erotic" or some such when i went to load your pic.)
Post the contents of your .ffs_batch.
Does the .ffs_batch need a line in there telling it to Quit, AutoClose="true, is it?
https://freefilesync.org/manual.php?topic=schedule-batch-jobsNote
Be sure to enable Auto-Close and Ignore errors/Cancel if you schedule the ffs_batch file to run under a different user account. With no one there to close the results dialog manually, the task would hang indefinitely.
It seems like FFS never finishes, and the task is retrying it over and over
Hmm. Each of the log files shows completed. Example:It seems like FFS never finishes, and the task is retrying it over and over xCSxXenon, 18 May 2023, 15:45
Hugh-Thumbdrive-Backup 5/17/2023 1:30:02 PM
Completed successfully
Items processed: 2 (11.0 GB)
Total time: 00:17:53
1:30:02 PM Info: Using non-default global settings:
Fail-safe file copy: Disabled
Copy locked files: Enabled
1:30:07 PM Info: Comparison finished: 133,007 items found – Time elapsed: 00:00:04
1:30:08 PM Info: Synchronizing folder pair: Mirror ->
C:\Users\hugha\Documents
D:\Documents
1:30:08 PM Info: Deleting file "D:\Documents\Outlook Files\~Outlook.pst.tmp"
1:30:08 PM Info: Updating file "D:\Documents\Outlook Files\Outlook.pst"
Windows 11 (Version: 22H2) – hugha (Hugh_2022_Dell) – Inspiron 14 7425 2-in-1 – Dell Inc.
It may be the autoclose setting. Please review the below:Post the contents of your .ffs_batch.
https://freefilesync.org/manual.php?topic=schedule-batch-jobs therube, 18 May 2023, 15:38Note
<?xml version="1.0" encoding="utf-8"?>
<FreeFileSync XmlType="BATCH" XmlFormat="17">
<Compare>
<Symlinks>Exclude</Symlinks>
<IgnoreTimeShift>1</IgnoreTimeShift>
</Compare>
<Synchronize>
<Variant>Mirror</Variant>
<DetectMovedFiles>false</DetectMovedFiles>
<DeletionPolicy>Permanent</DeletionPolicy>
<VersioningFolder Style="Replace"/>
</Synchronize>
<Filter>
<Include>
<Item>*</Item>
</Include>
<Exclude>
<Item>\System Volume Information\</Item>
<Item>\$Recycle.Bin\</Item>
<Item>\RECYCLE?\</Item>
<Item>\Recovery\</Item>
<Item>*\thumbs.db</Item>
<Item>*.log*</Item>
<Item>*.temp</Item>
<Item>*tmp.*</Item>
<Item>\Web and Websites Here\OLD NO LONGER CLIENTS\*.*</Item>
</Exclude>
</Filter>
<FolderPairs>
<Pair>
<Left>C:\Users\hugha\OneDrive\Desktop</Left>
<Right>\\readyshare\USB_Storage\Dell-Backups\Hugh\Desktop</Right>
</Pair>
<Pair>
<Left>C:\Users\hugha\Documents</Left>
<Right>\\readyshare\USB_Storage\Dell-Backups\Hugh\Documents</Right>
</Pair>
</FolderPairs>
<Errors Ignore="true" Retry="0" Delay="5"/>
<PostSyncCommand Condition="Completion"/>
<LogFolder/>
<EmailNotification Condition="Always"/>
<Batch>
<ProgressDialog Minimized="false" AutoClose="false"/>
<ErrorDialog>Show</ErrorDialog>
<PostSyncAction>None</PostSyncAction>
</Batch>
</FreeFileSync>
<Batch>
</Batch>
Yes! They are finishing but never closing
I changed it, I'll track how it goes, thanks for the assistance.Yes! They are finishing but never closing xCSxXenon, 18 May 2023, 18:21
Fixed in the next version: viewtopic.php?t=8535#p39347
Thanks! Editing the file above manually from autoclose = false to true did fix it for me.Fixed in the next version: viewtopic.php?t=8535#p39347 Zenju, 23 Jun 2023, 17:19
