The Last Revision does not SORT ITEMS CORRECTLY.
See Attached Pictures of Sorting By Name Up and Down
Last review (12.3 Released May 17.2023) does not sort items PROPERLY
I can't see anything on these pictures, but the sorting is most likely correct: first by color, then by name.
Sorry but if your read the name all items are GREEN and NUMBERED (00 รท 06).
Based on this the sequences should be :
[last Session]
00. - 5 Items
01. - 2 Items
02. - 4 Items
03. - 1 Item
04. - 2 Items
06. - 2 Items
Why Not ??
[last Session]
00. - 5 Items
01. - 2 Items
02. - 4 Items
03. - 1 Item
04. - 2 Items
06. - 2 Items
Why Not ??
One More information about this issue.
- I create a copy of mis-sorted items , adding , (previousname)+Copy.
- I did Open from the main menu and the program loaded it sorting exactly.
- Based on this I created a copy of ALL mis-sorted items and Opened them again
- I removed each of the mis-sorted Items and renamed the new one without Copy.
- NOW I HAVE THE LIST SORTED CORRECTLY.
This seems to me that Your Sort does not WORK Properly.
Regards
Regards
The pictures are super low quality and the text isn't legible
