Autodesk Docs Sync Issue
Sometimes when I sync between odrive and Autodesk Docs, it will delete the file from Docs on the web but keep the file on my local machine in a static "sync" status. I have my deletion setting to permanently delete and overwrite because otherwise it won't create a new version number on Docs.
