Hi, is there a way to stop the display of "Completed Successfully" window?
The batch job is run minimized and to close, but this always pops up.
Suggestions please, thank you!
Do not show "Completed Successfully"
If you saved it as a .ffs_batch configuration and checked the boxes to auto-close, it should work. Try saving it as a new config and overwriting itself
Thanks xCSxXenon ...
I saved, overwriting and, as you said, the window no longer appears! :-)
