Unfortunately I need help because a directory is not recognized and synchronized. My configuration is simple drive F should be synchronized with drive FFS F.
But a directory is left out. There is no filter in this regard.
As a test I copied a simple text file into the directory and started the scan again. Even now there was no positive result.
Question: what could be the reason for this and what if other (sub)directories are "forgotten". Unfortunately I can not check everything.
Does anyone have an idea and can help me. Thanks already in advance
folders are forgotten during synchronization
Another test:
1. All filter settings were deleted and a new search was performed. Result: the missing folder was found (but was not entered in the filter!).
2. the same(!) filter settings were set again and the search started. Result: Now the folder was also found.
Why only now?
Why only now?
So if you remove all filters and it works, but then put the filters back and now it doesn't work, the problem is your filter setup.
Post a screenshot of your filter settings and the excluded folder in a File explorer window
