i have some scripts that are executed after the sync is completed. The script location has been changed but in the list there are still the "old" locations. How can i clear the List? In the ffs_gui config file there is only the last script i've executed not the complete list.
Clean List of PostSyncCommands
Usually you can just use your arrow keys to highlight one and then push "DEL"
