A can not open and use FreeFileSync after new version even donated
petr.papanek
Dear, I am a bit confused that after new version update with donation I am not able to install, re-install use your application.
Would you mind fixing it for me?
Thank you
See attachment
Can you translate the Windows error(?)-message in attached file to English?
Screenshot in a proper format:
The "5" suggests "access denied", which suggest some third-party software is interfering with the installation: Anti virus, etc.
petr.papanek
Finaly after 3 times de-installation and re-installation rounds it has got fixed. Thx
