Thank you for "FreeFileSync" very good software.
Feature request:
The batch job *.batch, does not save the change of "View mode" (difference - Action).
<GridViewType>Difference</GridViewType>
Feature request: The batch job not save
What even is the point of (F11) 'switching' between difference and action?
Yes, you can change it with f11, but you always have to press f11, because it does not save the settings.
That's indeed an inconsistency: FFS indicates a changed configuration, but does not actually save GridViewType for an ffs_batch file. Fixed in 12.4.
