Option of Open in RealTimeSync should be split into Import and Load [SUGGESTION]
Synchronizator
Currently RealTimeSync in its File menu has 4 entries
New
Open
Save As..
Exit
I suggest splitting and renaming of the Open entry to Import Jobs which would allow only for loading up of FFS_BATCH files - and to Load Jobs which would allow only for loading up of FFS_REAL files. And then also the name of Save As... should be changed to Save Jobs, to further implicate / recall to user the differences [assuming the word "export" will not be used for something else]
Such change would avert stupid mistakes of inexperienced users who use Open to load up list of monitored folders, but instead of choosing a newer version from a FFS_BATCH file they choose the same / old ones contained within a FFS_REAL file - which result in no changes occurring when using RTS
Synchronizator
they choose the same / old ones contained within a FFS_REAL file - which result in no changes occurring when using RTS Synchronizator, 14 Jun 2023, 14:31
And such lack of expected changes can go unnoticed forever if the list is long and user will not check in a test if supposedly newly monitored locations really are
