From windows 10 to NAS DNS-325 ftp fail
FrTmu92320
From windows 10 to NAS DNS-325 ftp fail with the error message: (User/password is not Anonymous)
CURLE_QUOTE_ERROR: QUOT command failed with 550
550 Anonymous users can not delete files [curl_easy_perform]
Works fine with the same user/password on FileZilla Pro
Did you leave the password field empty in FreeFileSync?
FrTmu92320
No i have put the password always, OK with fileZila.
ftp://User@192.168.1.100/Volume_1/Backpup|pass64=xxxxxxxxxxxx
I am in local.
I mean, did you check the "Enter at login" password option? Otherwise I do not see how you could end up wit an anonymous login.
FrTmu92320
Where is it the option "Enter at login" ?
My NAS does not permit Anonymous en FTP
Really? The error message seems to suggest that FFS has successfully connected with the NAS as an anonymous user.
