I have installed FFS 3.6 as portable x64
When I launch my JulienSyncDb.ffs_batch
(Local Folder <-> USB drive folder)
it ask for Julien\sync.ffs.db file
I have already Julien\sync.x64.ffs.db
If I try to rename Julien\sync.x64.ffs.db into Julien\sync.ffs.db
I have a "wrong format" error message
Could you please help ?
sync.x64.ffs.db
Are you sure you're using the x64 build of FreeFileSync? The x64 build should
ask for "sync.x64.ffs.db" and not for "sync.ffs.db".
You are right
I had this old 3.2 x86 still installed in the x86 program file folder
thanks
Julien
thanks
Julien
