Dear FreeFileSync team,
Currently, in order to achieve flawless functionality with RealTimeSync, it requires some additional steps. First, you need to (export) save the configuration .ffs_batch file and then open RealTimeSync. After that, you have to enter the command line or drop the .ffs_batch file into RealTimeSync and click Start or (export) save the RealTimeSync file. Finally, you need to move the RealTimeSync .ffs_real file to Shell:startup. This process involves too many steps. Could you please add a RealTimeSync icon that, when clicked, automates all the aforementioned steps? This would make it easier for individuals with limited or no computer knowledge to use this software. For example, after selecting the left and right folders and configuring the synchronization settings, they can simply click on the RealTimeSync icon, and everything will be set up (meaning it's a set-and-forget solution).
Also please add Implicit SSL/TLS option for FTP connect.
Thank you so much, and I hope this message reaches the development team and administrators, enabling them to make this feature possible.
[Feature request]1 click Seamless RealTimeSync icon on FreeFileSync Dashboard
Never mind, I found an app that automates all those steps and auto-sync to cloud service with 3 steps.
1. Enter login info
2. Select the local folder
3. Click sync
And everything is working in the background.
1. Enter login info
3. Click sync
