There are so many new icons on the info bar that it don't foit together with the "Compare/Sync" bar.
Is there a way to make them smaller (hide icons, smaller text etc)
Bars no longer fit both on one line
The left half of the icons should be shown above the Compare results, the right half below the Compare results.
In the FFS GUI, try using Tools / Reset Layout.
Well to be fair, they should look correct if you are able to move them.
