Synchronizing folders relative to sync.ffs_gui
CarstenF
Edit: let me ask my question differently.
I have a USB-Stick on my keychain with several folders that I want to sync to a SFTP for mostly backup purposes.
So I placed a sync.ffs_gui in each folder.
In that ffs_gui I wrote "./" as a relative path that should point to the folder where the file is in (after double-click-opening).
Under Windows this works.
Under Linux Mint it resolves to the home folder.
Is this a bug or should I use a different path so it works under both Linux and Windows?
CarstenF
I found a workaround.
Create a file like sync.sh, make it executable and in it you write "freefilesync sync.ffs_gui".
Then it is launching with the correct working directory.
I tried to fix /usr/share/applications/FreeFileSync.desktop but there is something wrong not related to FFS.
Ther are some whacky solutions on the internet but most fail if theres a space in the path and they cause all sorts of other problems.
Indeed, the working directory is not set on Linux the same way as it is done on Windows when you double-click on a ffs_gui file.
I tried to fix /usr/share/applications/FreeFileSync.desktop but there is something wrong not related to FFS. CarstenF, 03 Aug 2023, 11:59
The following might be a workaround for FreeFileSync.desktop:
Exec=/bin/bash -c 'FFS_ARG="%f"; cd "$(dirname "$FFS_ARG")"; "/opt/FreeFileSync/FreeFileSync" "$FFS_ARG"'
Update: Apparently this doesn't work when there are spaces in the file paths.
CarstenF
I was at that point too, this does not work if a space is in the path.
The desktop file's "Exec" is parsed once before the command is executed, so we need some escaping. The following version should do the trick:
Exec=/bin/sh -c "filePath=%f; cd \"$(dirname \"$filePath\")\";  /opt/FreeFileSync/FreeFileSync \"$filePath\""
Some implementation details about Exec I found out:
• either %f or %F is replaced, and exactly once
• %f is replaced by file path with single quotes if path contains spaces. (This is why the Exec example above must start with double quotes)
• %F is replaced by a list of single-quoted paths if spaces occur inside them.
CarstenF
YES, that works.
Thank you.
I'll make
Exec=/bin/sh -c "filePath=%f; cd \"$(dirname \"$filePath\")\";  /opt/FreeFileSync/FreeFileSync \"$filePath\"; rm ~/.config/FreeFileSync/LastRun.ffs_gui"
of it, because if I open FFS via desktop shortcut by accident I might overwrite my backup with my home folder data. Would be nice if there was an option not to save that file automatically.
Here's an improved version using bash arrays. In addition to single file path arguments it works with:
• multiple path arguments
• zero arguments
Exec=/bin/bash -c "paths=(%F); cd \"\$(dirname \"\${paths[0]}\")\"; /opt/FreeFileSync/FreeFileSync \"\${paths[@]}\" "
Example: Exec will make bash execute a command like the following:
paths=('folder/spaced file.txt'); cd "$(dirname "${paths[0]}")"; /opt/FreeFileSync/FreeFileSync "${paths[@]}"
Update 2023-09-16: Apparently the syntax does not work on all Linux systems, e.g. it fails with a syntax error on WSL2 and on Kubuntu: viewtopic.php?t=10666
