Delete a synchronization that is no longer needed
I have a synchronization that I no longer need. I do not see any way of deleting it. Any helpould be greatly appreciated.
Yep same question here. short from re installation.
You mean in the configuration list? Just select and press the DEL key.
Thank you, that worked. I was clicking on the synchronization and bringing it into the window and then tried to delete it. I should have just hit the down arrow and put my mouse pointer on the highlighted configuration to delete and hit the delete key.
It should have worked both ways: as long as the config panel has input focus, it will delete all selected configurations upon pressing DEL.
