About files "sync.ffs_db"
johnzhang
Hello, may I ask if it's possible to modify the "sync.ffs_db" file under Windows to make it a system file and a hidden file (this can be achieved using the command line "attrib "sync.ffs_db" +s +h")? Alternatively, is there an option in the settings to achieve something similar?
I currently have Windows File Explorer set to show hidden files but not show hidden system files, so I would like FFS to automatically set the "sync.ffs_db" file with system and hidden attributes.
