I'm trying to install the donation edition on my Linux PC.
The file is executable, but nothing happens when I try to run it.
What am I doing wrong?
Thanks in advance,
Steve
Bodhi linux installer doesn't run
What output do you get when you try to start the installer via command line?
So what, you...
chmod +x free*.run
& then your run free*.run
And then what happened?
chmod +x free*.run
Nothing
