Hi!
I'm trying to take advantage of Versioning feature in conjunction with macros in Synchronization settings.
I want to be able to create folders with format like this Y:\DeletedItems\%year%\%month%\%day% - %weekday%. I have changed Delte files: to Versioning and Naming convention: to Replace like said in manual. However my DeletedItems after synchronization only contains actual folders with timestamp at the end of each deleted file.
Thanks for helping!
Versioning - Replace
Just tested on Win7 and it works for me.
Tested on Windows 8 and it's working but not on my Windows Server 2008...
It's unlikely this feature is dependent on the OS. Maybe you're testing with different configurations?
I hope it's me...but the only thing that's different is that Windows 8 configuration uses local drive for sync...
I have also tried local drive sync on Windows Server 2008 and this feature also doesn't work :(
Got it working by creating new configuration from scratch...
