Configuring the resume of a partial file copy
mangeli67
Hi, I use the donor version of FFS and am copying large files (>100GB) with ADSL over VPN (very low speed).
When FFS crashes it restarts the copy and that is a problem for me. Larger files it cannot complete as it crashes before the end of the copy and restarts each time.
I know I can use robocopy with the -Z option or Rsync with the --partial option, but I like FFS.
How can I do this?
therube
(Aside from your question...)
When FFS crashes
Any message given as to the cause?
mangeli67
Only to zip dump file and send by email
The crashes happen inside Windows functions:
ntdll.dll!RtlQueryPerformanceCounter(), or
ntdll.dll!RtlSleepConditionVariableSRW(), or
gdi32.dll!InternalDeleteObject()
These are not caused by an ordinary software bug. Either your Windows installation got corrupted, or you have a hardware error.
It might help to run:
Dism /Online /Cleanup-Image /RestoreHealth
sfc /scannow
mangeli67
Thank's.
