FreeFileSync 13: Will old jobs from earlier versions work?
TheExpert
Hi all,
with FreeFileSync 13 there's big change regarding the synchronization. So I'm asking what happens with the old jobs created with former versions? Will they work as they worked in the past? Or do we have to adapt the jobs because of the new synchronization features?
Thank you.
therube
Yes.
If you want to incorporate the new features in the sync, then you need to specifically enable them in the sync.
(And you need to familiarize yourself in how they operate so as not to be bit by something unexpected.)
Mine work fine
TheExpert
OK, thank you for the quick answers. I will try if everything is working fine after updating to FreeFileSync 13.
