When I backup many files to an USB stick the speed falls to 0 when the USB stick gets hot.
Must use pause for a while and then restart (and then the speed is OK for a while).
Is there a way to do this automaticly? Take a minute pause each 5 minutes or so?
If not, is this an idea for a new feature?
Auto pause to prevent USB from getting to hot
Get a better flash drive. If it gets hot enough to stop transferring, it's going to be dead before you know it. The time to implement a feature to bandaid bad hardware is not worth it
Do you know that to be the case? As in if the USB drive hits 85C, it says, "whoa there, time for a timeout!".the speed falls to 0 when the USB stick gets hot
Is it possible that the drive has cached data, that it needs to physically write out, & during that time it tells FFS, "send no more data, until I say, OK, OK?".
Does an overall transfer of data take an expected amount of time, regardless of "0" speed times?
As in, is a slow steady "speed" just as fast as a speed that is much faster, at times, but that also varies greatly - even dropping to 0 at times? (Sort of like the tortoise & the hare.)
