Feature Request: Specify threads for directory pairs on the command line at runtime
ZBR
I am using FreeFileSync v13.0 portable via a Windows batch file to sync several different directory pairs on multiple drives (3+). I am using a generic/comman .FFS_BATCH configuration file which is common for all the syncing. I have noticed FFS only uses one thread per directory when performing the syncs during runtime.
I would like to specify the number of threads for each folder on the command line at runtime. Also, it would be nice to be able to specify a default thread count (in the global config) to be used when new folders are specified for either the source or destination.
xCSxXenon was very helpful with trying to understand what I was attempting to do.
More information can be found in viewtopic.php?t=10713
Thank you.
