Where is "last sync" stored?
kvebe
For backup/restore purposes: where is the "last sync" stored?
Or better: what should I do to restore the correct "last sync", as I restored a Windows image and now the "last sync" gives older data.
Thank you
Cheers
Kees
"GlobalSettings.xml" in your Appdata\Roaming folder
Better yet, just run the syncs and the 'last sync' will update
kvebe
All of them or just one will do ?
Each config has its own 'last sync' status
Thiersee
Better yet, just run the syncs and the 'last sync' will update xCSxXenon, 28 Sep 2023, 13:57
Sorry, but it doesn't work!
I restored yesterday a Windows-Image with an older one: the "Last Sync" had the date contained in the older Image, even if I just had the sync three days before, with no possibility tho change it!
And to do the sync again ist possible, but it isn't a solution/answer to the question!
Regards, Thiersee
2023-10-11 10_07_03-C__Users_j.lewis_AppData_Roaming_FreeFileSync_GlobalSettings.xml - Notepad++ [Ad.jpg
2023-10-11 10_07_03-C__Users_j.lewis_AppData_Roaming_FreeFileSync_GlobalSettings.xml - Notepad++ [Ad.jpg (80.72 KiB) Viewed 1935 times
Here's a picture of the section in the GlobalSettings.xml that tracks/reports the 'last sync' status. That long number is what you'd have to modify for each config/line. You have to modify each one or run the syncs to change the data
