Moving files from folders
Is there a way to move ten files from ten folders into one folder?
You can create 10 folders pairs, each pair uses one of the ten source folders on the left and then they all use the same destination folder on the right. Use 'update' sync method. Set up filters to only include the one file that is in each source folder. Should be good after that
