Hello all,
need one solution for one way(Mirror) file sync between two different location on different machine, and cannot accessible at same time.
E.G. one PC(named "Offline-PC") dont have network connection it can be only accessible via pendrive.
would like to sync Multiple file/folders ~300Gb/1M files to other PC (Named "online-PC")
is there any way i can create "Files List" on Online-PC and take the list to Offline-PC
and command software only copy files in pendrive NOT available in "file list" ?? and will take it to online-PC paste it with replace it?
need help for this unique requirement,
Sync two location not accessible at same time and machine
That isn't possible with FFS
You'd have to mirror a full copy to an external device from offline-PC, then mirror the external device to the online-PC
