When 'dragging-and-dropping' my batch file into the application, it doesn't display a command line.
I'm running macOS Sonoma 14.0 on a MacBook Air M2. The source folder is iCloud, and the output folder is a Samsung SSD.
I've uninstalled and reinstalled the program to no avail.
Any recommendations or advice would be greatly appreciated! :)
RealTimeSync Command Line Error
1. "you're dropping it wrong".
2. Even if 1 is true, RTS should understand what you mean and just load the config instead of setting it's directory path => fixed for the next release
Thank you!
Thought it was just a minor bug. Hopefully it can be working soon.
