Possible to connect via WebDAV?
Mirk0
This question comes from a friend of mine - i use my copy of FFS for other purposes - and he wants to know, if a connection via WebDAV is possible with FFS. His target server doesn't support FTP. There are only the options FTP, SFTP and Google Drive available? Any advice?
Mirk0
Thanks, the mounting method works with Windows and Linux.
But i have a weird issue on both OS. I can upload and download files within the file explorer, but FFS does give me 2 errors when trying to synchronize. First, it says, that there is not enough space available on the target server and second, it can create folders and sub-folders, but can't write files. If i do it manually with Filezilla - which doesn't have a decent sync feature - than everything works. Does the sync process do anything different and where are coming the errors from? File permissions seems to be working.
I am doing this through remote access on my friends machine, but that shouldn't make any difference
