I run FFS on a mac mini I use as a home server. I use Automator to run the batch file twice a day. It works great expect for one thing. After it completes the completion window stays open until you close it. If I don't check on my server for 3 or 4 days I get 6 to 8 completion windows I need to close.
Is there anyway to automate the closing of the completion window?
I have a thought on how to make an Automator to close it but wanted to see if there was a way to do it in the FFS application before I do that.
Completion Window
As indicated here, make sure you checkmarked "Auto-close" when saving your *.ffs_batch file.
Ugh, I can't believe I missed that. Thank you so much for the help. Such an easy fix.
Outstanding, thanks very much, not sure how I missed that either.
