sync.ffs_db conflicts and increases
Cloud folders and local folders are synced bi-directionally. sync.ffs_db conflicts and increases in the cloud folder every time you synchronize. I don't know the cause. Please someone help me...
What does "conflicts and increases" mean?
Thank you for contacting us. When new information is written and saved to sync.ffs_db during synchronization, there is already a sync.ffs_db, so there will be a conflict, and the number of files called "copy of sync.ffs_db" will increase rapidly.
What cloud provider are you using?
FFS uses the same sync.ffs_db file every time it runs, so "there is already a sync.ffs_db" shouldn't be possible. When the db file is changed, it is simply updated, not replaced
