This is an excellent backup software that I really like and have been using,
Make a suggestion.
The script software you want to run can add a locking function.
Benefit: It is necessary to unlock to view the backup path inside, to avoid tampering with the settings inside. If the computer is poisoned, we cannot know where our backup file path is placed, as it can be backed up to any computer on the local area network. If hackers know the backup path, they can also attack the computer that knows the path together. By adding a lock, we can safely protect our backup file path from others, Therefore, the chances of being attacked and ransomware are relatively small. I hope it can be improved. Thank you very much.
If you want to backup the running script, you can add a locking function.
